How do I test the O2 sensor?
Old Dec 28, 2009 | 09:40 PM
HondaAccordEX94's Avatar
Almost A Senior Member
Default How do I test the O2 sensor?
Okay, I know basically everything I need to know except one thing.
Alright, I'm going to be testing it with a Volt meter. So I locate and disconnect the sensor. There are 4 cables. I've always been told to use the solid black cable. But this cable along with the others goes to the plug. Do I just snip it in half, test it, and then crimp it back together after the test? I was just worried about the crimp and heat and whether or not this would mess up the O2 sensor if it were indeed a working sensor and I were to put it back in the car.
Old Dec 29, 2009 | 12:33 AM
finch13's Avatar
You should be able to test it at the plug... no cutting.
pondrun
Nov 8, 2021 09:40 AM
x13darkmatter
Aug 9, 2012 10:04 AM
dmost30
Sep 8, 2008 12:42 AM
HORSEPOWERJUNKIE2007
Mar 31, 2008 04:53 PM
fireballer44
Oct 30, 2006 01:11 PM
