how far can a brake cylinder go?
Old Jul 17, 2007 | 04:38 PM
noboundaries6289's Avatar
Default how far can a brake cylinder go?
hey all, my master brake cylinder is leaking. Funds are tight, so how long do you think I can ride? It's not leaking very bad but it is wet on the booster. When I had my probe, the mech. told me I had about 3-4 months before it failed. Can this last a month or two before replacing? or is it a must replace now part. thanks for the input
Old Jul 17, 2007 | 07:35 PM
Chiovnidca's Avatar
Default RE: how far can a brake cylinder go?
No way to tell. How bad do you want your car to stop the next time you hit the brakes?
Old Jul 17, 2007 | 09:20 PM
smaglik's Avatar
ORIGINAL: Chiovnidca
+1
Old Jul 17, 2007 | 09:54 PM
new plan, got enough $$ to buy part, not enough for labor. anyone know any simple steps to install it? thanx
Old Jul 17, 2007 | 11:53 PM
ORIGINAL: noboundaries6289
...or is it a must replace now part. thanks for the input
Are you going to be driving anywhere behind me??
Bolting it in is easy. Do you know how to bleed your brakes?
Have a bunch of rags. It'll get messy and brake fluid will eat paint off anything.
Get a flare wrench so you don't bugger up the gland nuts on the brake lines. Disconnect the steel brake lines.
2 bolts attach the MC to the vacuum booster. Then it 'just' pulls out. I don't have a '95 so I don't know whether you need to get anything out of the way.
Carefully compare the length of the new & old piston rod. Hope they're exactly the same. If not, there's a strange measuring tool and you adjust the push rod under the brake pedal.
Bench bleed the new MC. Get a couple hoses that fit where the brake lines go, loop them up into the reservoir. Fill it & pump the piston rod. After is sputters the air out, you'll be pumping liquid back into the reservoir to remove ALL the air bubbles.
When you install it the fluid will drip all over. The rags, remember?
Then bleed your brakes. Then bleed your ABS (if you have ABS).
Old Jul 22, 2007 | 08:33 PM
once again, new plan. I have budgeted enough money to pay or labor. yay.
Chris Jameson
Feb 19, 2013 06:39 AM
garretthes
May 30, 2007 06:20 PM
mkaresh
Apr 13, 2007 03:24 PM
dinzer
Aug 19, 2005 09:34 PM
jayhova804
May 3, 2005 09:22 AM
