Ignition Coil question
Hi there, I just bought my first Honda. It's a 2002 Accord SE with a 2.3l I4 VTEC. Sadly it's an automatic... Anyways, car is in pretty great shape, but the previous owner who only owned it for about 4 months doesn't know any of it's history.
So I'm doing a tune up. Just did the oil this weekend and now, because I'm stationed overseas, I need to order a full tune up online. Problem I'm having is the ignition coil either has the little spring at the end or a solid contact.
Here are the two I mean:
They are all a variation of those two. Question is, which one should I buy??
Thanks.
Thanks.
Replacing coils that aren't bad, would be like replacing a distributor that wasn't bad. You could do it, but you'd just be lining a parts companies pocket. Nowadays, change the plugs, air filters, maybe flush the tranny at the due mileage. Not much else needs be done. (besides regularly scheduled fluid maintenance)
James Glenn
Dec 30, 2014 09:04 PM
phantomgrey92
Oct 9, 2013 04:45 PM
