Ignition Coil question
Old Jun 23, 2013 | 10:37 AM
rklettke's Avatar
Default Ignition Coil question
Hi there, I just bought my first Honda. It's a 2002 Accord SE with a 2.3l I4 VTEC. Sadly it's an automatic... Anyways, car is in pretty great shape, but the previous owner who only owned it for about 4 months doesn't know any of it's history.
So I'm doing a tune up. Just did the oil this weekend and now, because I'm stationed overseas, I need to order a full tune up online. Problem I'm having is the ignition coil either has the little spring at the end or a solid contact.
Here are the two I mean:
Delphi GN10171 Ignition Coil : Amazon.com : Automotive Delphi GN10171 Ignition Coil : Amazon.com : Automotive
OEM 5100A Ignition Coil : Amazon.com : Automotive OEM 5100A Ignition Coil : Amazon.com : Automotive
They are all a variation of those two. Question is, which one should I buy??
Thanks.
Old Jun 23, 2013 | 11:35 AM
Two things....usually if the coil isn't bad, I would not replace it as part of a tune up....again just me.
Next, memory tells me the coil has a solid contact.
Old Jul 1, 2013 | 10:51 PM
stang99x's Avatar
Replacing coils that aren't bad, would be like replacing a distributor that wasn't bad. You could do it, but you'd just be lining a parts companies pocket. Nowadays, change the plugs, air filters, maybe flush the tranny at the due mileage. Not much else needs be done. (besides regularly scheduled fluid maintenance)
phantomgrey92
Oct 9, 2013 04:45 PM
randy93
Nov 17, 2007 11:08 PM
klyphman
Oct 12, 2006 04:43 AM
accordlowered04
Jul 10, 2006 05:32 AM
