Irritating Vibration
Old May 13, 2006 | 12:31 AM
JW
Default Irritating Vibration
Hello, I have a 92 Honda Accord LX, automatic.
I recently replaced the CV axles along with all motor mounts timing belts etc.,
I have a small vibration from the engine through the floor and steering wheel. I can't imagine what could be wrong?????
I thought that the motor mounts would stop the vibration.
The car has had a wheel alignment when I replaced all 4 tires, so that can't be it.
Is it possible that the transmission is going bad???
It is very apparent at about 70 mph and then starts to lessen around 80. (Good excuse to drive fast)
It feels like the transmission is up against the floor of the car.
If I remember correctly on a manual transmission their is a rubber damper on the clutch,,,anything like that on the automatic transmission????
Help please!!!
Old May 13, 2006 | 12:45 AM
deserthonda's Avatar
Default RE: Irritating Vibration
it sounds like tires out of balance ...have the tires rebalanced
good excuse to drive faster ...OR stay below 70..
Old Sep 2, 2006 | 08:24 PM
accord_rojo
I was told that Accords 90-94 sometimes make that vibration between 2,000 and 3, 000 RPM’s. They do it because the EGR ports are dirty. Have you ever clean your EGR ports? I got instructions on how to change them somewhere in the forum but I don’t remember where. Good luck.
Old Sep 3, 2006 | 01:34 PM
Chiovnidca's Avatar
ORIGINAL: JW
Did it have the vibration before this work was done? Are the balancer shafts properly timed?
Old Feb 17, 2007 | 10:57 AM
accord_rojo
Did you ever found the solution to the vibration? I am now experiencing something similar. The vibration actually makes the front/driver wheel come lose. I have done an alignment, balanced all 4 tires, replaced the hub assembly (driver side); I have even switch rims because I was told maybe the rim was defected but nothing. I get the vibration at around 100-110 Km/hr which would be 65-70Ml/hr, but if I go faster at 140Km/hr, (90Ml/hr) the vibration goes away.
The other thing I like to mention is that I have a 5 speed; it is a 1990 LX. You have an automatic but it might not be the transmission. I had changed the EGR ports in the past and I noticed a difference but only when driving slow. (Between 40-60Km/hr)
This one is a hard one, I do not know what to do, I have taken it to mechanics and no one knows. L
Did you have any wheels go loose as a result of the vibration? Did you do any work right before you got the vibration? When did this problem started?
Thanks!
Old Feb 27, 2007 | 02:03 AM
Alex_Rus
Hi ppl...
I was just going through the net looking to find the answer for the same problem...
3 days ago my mechanic changed the left and right Axles on my car.... 94 Accord (5 speed).... After the change the car drives much better, but I noticed vibration when accelerating ... between 2000 - 3500 RPM only in the 1st and 2nd Gears... (under 45 mph)...
When my mechanic was changing the axles... some transmission oil spilled out, but when he finished the job he added some oil to the transmission...
Weird...
Yes, I had alignment done right after the axles were replaced.... Cars goes perfectly straight. Hope someone helps out....
Old Feb 27, 2007 | 11:45 AM
ORIGINAL: Alex_Rus
Hi ppl...
Weird...
Alex # 1 you should not ask questions on someone else's post you should start your own or it could get confusing and # 2 sounds like you got some bad axles installed ,, sounds like a bad inner cv joint
Old Feb 27, 2007 | 04:58 PM
YeuEmMaiMai's Avatar
ORIGINAL: accord_rojo
Glogged egr will lead to hesiation between 1500-2500 rpms...
OP a bad lower ball joint will casuse the problems you are describing
Old Feb 28, 2007 | 12:29 AM
Alex_Rus
I kind of disagree .... If the ball joint would be bad, the vibration be constant, not only on the low rpms...
Old Feb 28, 2007 | 08:15 PM
not in all cases. my 94 had a bad joint (lower driver side) and it only vibrated at speeds of 60-70. Replaced the joint and vibration was gone
my current car had 2 bad lower ball joints and all it did was require more steering corrections than usual.
