jb weld
Old Sep 2, 2009 | 08:10 PM
allthatremains
Default jb weld
will this work on a radiator temporarily? has anyone ever used this stuff i hear its pretty good for all kinds of ish
Old Sep 3, 2009 | 10:51 AM
As epoxy goes, it GOOD stuff. But the radiator is under pressure so I'd want more than "good" stuff.
I'd be afraid to use it on a radiator for more than a day or 2. When the stuff cures, it becomes a brittle-fracture material for the most part. With little or no warning your repair will blow wide open.
Old Sep 3, 2009 | 01:40 PM
Thumbs up Hi Member
There is a product at your local AutoZone stores that goes by the name Liquid Steel..
Clean it, spread it on like glue, let it cure..then you can even sand it , gring it, and paint it ..works great..It becomes a Liquid Steel..I've used it quite often on all kinds of projects...
Old Sep 3, 2009 | 09:40 PM
tlroberts23
It depends on the location, on mine I had a leak on the top at the seam and i triedjb weld it held for a few days but it did not hold, like someone stated earlier the radiator is under alot of pressure so this wll probably not last long. I found a radiator for $100 bucks at a local parts store.
DanCoupe
Aug 25, 2012 11:26 AM
GraphiteZ
Dec 2, 2011 11:37 PM
