K and N Air Filter
Old Mar 24, 2008 | 12:52 PM
08AccordEXV6
Default K and N Air Filter
Hey,
I know the pros, but what are the cons. Can it allow to much air flow that will cause particles to get in and cause problems?
Thanks
Old Mar 24, 2008 | 04:10 PM
Default RE: K and N Air Filter
There's no such thing as too much air. The air flow is limited by the displacement of the engine.The mosta filter can possibly do is to be a very small part of the total pressure drop thru the entire intake system.
Separate from this, people have said K&N allows more dirt thru, which can be measured as silicates in your oil. That is, if you have oil analysis done before and after installing the K&N. I haven't done that so I can't say firsthand...
Another thing is more Hondas these days are equipped with a hot-wire air flow sensor in the airfilter housing. You need to be careful to NOT over-oil a K&N filter so you don't get oil deposition on that sensor.
Special_K
Aug 12, 2011 04:16 PM
bjr001
Mar 5, 2010 07:31 PM
08AccordEXV6
Dec 30, 2007 01:58 AM
