k20 v. h22...which one is better
Old Nov 16, 2007 | 12:18 PM
SteveO_f22a's Avatar
Default k20 v. h22...which one is better
i have an f22a6 motor in my Ace and im thinking about what motor to put in. which is better, a k20 or an h22?
and since an h22 is 2.2l should i just do a head swap, would it be best to do a motor swap?
Old Nov 16, 2007 | 01:00 PM
falkore24's Avatar
Default RE: k20 v. h22...which one is better
The head swap is the best idea ..... the cast iron sleeves in the F engine are better than the FRM ones in the H22. As I pointed out on another of your threads, the K spins the wrong way, so you'd need a lot of custom work and a new tranny.
Old Nov 16, 2007 | 03:15 PM
Chiovnidca's Avatar
A k24 would be better. More work though.
Old Nov 16, 2007 | 04:51 PM
falkore24's Avatar
you prefer the k24 over the k20? It can't rev nearly as high safely.
Old Nov 16, 2007 | 06:21 PM
how much do h22 heads cost?
Old Nov 16, 2007 | 08:45 PM
nafango2's Avatar
about $350.
Old Nov 16, 2007 | 09:13 PM
nice...how much hp. like 220?
Old Nov 16, 2007 | 09:15 PM
BlkCurrantKord's Avatar
Stay with the F22a6, go N/A
contact www.bisimoto.com
Old Nov 16, 2007 | 09:18 PM
nafango2's Avatar
that you get from a new head?
+10ish? If that?
The higher power comes from higher compression, which is mostly because of the pistons. I spose you could get new pistons and a new head, complete with solid-state ign and a knock sensor to retard timing, and then you could get about 200+, but for that effort + $, might as well just get one of those engines^. Altough a K engine would not fit without serious modification to the vehicle.
Old Nov 17, 2007 | 09:24 AM
Chiovnidca's Avatar
ORIGINAL: falkore24
Yea, for an accord. A k20 would be a dog driving around normally. The k24 has more power at lower rpms, would be a much better match for a heavy accord.
