Loosing Oil
Old Nov 12, 2007 | 01:59 PM
Mikkos's Avatar
Default Loosing Oil
Hello Guys!
I have a 2001 Accord EX with a 4cyl. I currently have 193,000 miles on it and I've notice two things. Between oil changes, I am adding about 2 quarts of oil and I've noticed that my muffler is greasy and looks like oil is coming out thru the muffler. I haven't seen any leaks of oil in the garage at all so I know it's going somewhere. The dealer states that the oil rings may be worn. Any advice?
[/align]
Old Nov 12, 2007 | 02:08 PM
falkore24's Avatar
Default RE: Loosing Oil
check the engine's compression. That should tell you the condition of the rings and valve seats.
Old Nov 12, 2007 | 03:26 PM
sir_nasty's Avatar
Also, a car that is burning oil won't neccessarily blow blue smoke right away. The black stuff dripping off the exhaust is most likely from condensation collecting dirty exhaust particals so it has that black look. As was stated, if you don't have a leak do a compression test and you'll know if the rings are shot.
Old Nov 14, 2007 | 12:36 PM
Mikkos's Avatar
Where could the oil be going?
Old Nov 14, 2007 | 02:25 PM
falkore24's Avatar
out the tailpipe.
Old Nov 14, 2007 | 09:24 PM
Mikkos's Avatar
I did notice that the tail pipe seem to be greasy and oily. I'm sure that this will cause others problems if not fixed in a hurry. I have an appointment to take the car in on next week. I hope that I don't damage anything else.
[/align]
Old Jan 25, 2008 | 12:26 PM
Mikkos's Avatar
IF the rings are shot, will this mean that I would have to get the engine replaced? What does something like that cost?
Old Jan 31, 2008 | 11:02 PM
mihalis's Avatar
At least this was not happening to you when your car was new. My 07 Accord for whatever reason was leaking and burning oil...car had only 20K miles when I discovered the problem. Dealer tells me...car is fine!
Old Feb 1, 2008 | 12:15 AM
Nova's Avatar
Here are a couple things you can do if it your rings are wearing...
Give each cylinder a good dose of WD-40.
Get some "Stop-Leak" Oil treatment and add it to your oil at your next change.
Get a friend to help you; particularly with a car. When cold, get your friend to stand behind the car and watch the exhaust smoke. Start the car. If they see BLUE smoke right after a cold start, then your problem is vavle guides.
If you get no smoke, then have them follow you around the block. Once you are driving, go full throttle till about 5000 RPM's in 1st gear, then proceed to change gears. Once you are in third, go from 2000 RPM, and then again, go full throttle till 3500 RPM's.
If it emmits ANY amount of BLUE smoke, then your piston rings are worn, and you must resort to oil additives.
BLACK smoke is a VERY different issue. If your friend comments on the amount of black smoke you are getting, then you should go clean your air flow meter, replace the air filter, and clean the carb(FI?) with CARB and CHOKE cleaner...
Old Feb 3, 2008 | 08:08 AM
norm1971
I have a 2007 Accord wich is loosing about 3/4 of a quart of oil every 3500miles. My concern is will this gets worse as the car gets older.
Plannig to call Honda a document this just incase I needa new engine at 100k.
Anyone else see this in their accords?
