Maintenance Light Turned Red.
Old Sep 22, 2008 | 09:13 PM
mrbaysick's Avatar
Default Maintenance Light Turned Red.
so today my maintenance light turned red today.I was asking my friends what i should do.some said get a tune up and some said oil change?So im kinda confused on what to do.Any ideas on whats wrong?
Old Sep 22, 2008 | 09:37 PM
noehjuan01's Avatar
Default RE: Maintenance Light Turned Red.
Depending on the year, my '98 Accord maintenance light comes on about every 7500 and I change my oil every 4k and reset the light myself when it comes on.
Check your owner's manual, there may be a section that tells you how to reset the light.
Old Sep 22, 2008 | 09:41 PM
it is not set off my anything it is purely mileage. to reset it stick your key in the hole on the gauge cluster near it.
Old Sep 22, 2008 | 11:04 PM
mrbaysick's Avatar
Thanks!yeah it turned back to green after i stuck my key in.My ABS light turned on tho?
Old Sep 23, 2008 | 01:50 PM
RTexasF's Avatar
Super Member
The ABS light means there is a malfunction within the ABS system, not bueno. When was the last time the brake system was flushed? Honda ABS systems are sensitive to dirty fluid, they don't like it. Have it checked after you confirm the fluid is at the max level and looks clean.
818coupe
Jul 23, 2019 02:36 PM
handro0329
Jan 20, 2011 12:04 AM
Reboticon
Aug 24, 2010 06:50 AM
emgomez
Jun 21, 2008 01:48 AM
hotrod01
Nov 11, 2005 01:28 AM
