Max natural hp 98-2002?
Old Jun 30, 2008 | 10:52 AM
KevinAccord's Avatar
Default RE: Max nature hp 98-2002?
NAZZZZ ftw[sm=nxsmile.gif]
Old Jun 30, 2008 | 11:37 AM
Shotgun Earl's Avatar
Thank you to the three people listed here. I did not know I had "natural" as nature in the post heading but it seems most people got what I was trying to say. What they didn't get was that I wanted a answer that did not include forced induction. (Nas, Turbo, blower)
ORIGINAL: falkore24
The J30A1 could do 300HP NA, but as mentioned, it would take a lot of money ..... and it wouldn't really be a J30A1 anymore after you swap to a J32A2 head, High Comp pistons notched for the larger valves, PNP + 3 angle valve job with double springs and titanium retainers ..... not to mention all bolt-ons, fuel upgrades and tuning.
That is a lot of work...
ORIGINAL: YeuEmMaiMai
the best you can do on bolt-ons is about 35-40 HP.........one of the MAJOR limiting factors is the small valve size of the J30a
headers and axle back = 25 hp
intake about 10 hp
CL type S cams about 5 hp
So I can pretty much get the the engine to 235 - 240 with no problem. Not bad... What would be the prices on something like this?
ORIGINAL: 03Sleeper
K series ftw. I think some dude on k20a added two modifcations to the block (type s IM and exhaust), kpro and that led to something around 250whp. just rebuilding the engine w/ stronger internals, etc. could possibly land you in the ~270 whp range.
k swap ranged from 800 (k24a4) to 1000 (k24a2) to 1200 (k20a2)
EDIT- but i disgress.....w/ your 2002 accord making 300.....i say go FI or Nitrous.
What are the torque numbers that go with these swaps? Would one have 270hp but 160 torque? That is one of the reasons I like the J-family engines.
Old Jun 30, 2008 | 05:38 PM
Default RE: Max natural hp 98-2002?
Also can a J37 swap be done?
Old Jun 30, 2008 | 06:00 PM
03Sleeper's Avatar
well, the k24a4 block is pretty well balanced....but you're starting low. i see what you mean....but at the same time a N/A 4 banger would be more fuel efficient than a 6 cylinder 4 banger
k24a4 160 hp/161 ft lbs torque
k24a2 205/ 162 ft lbs torque
k20a2 200/~141 ft lbs
but honestly, if you really want to push 300 swap in a J35A8 (TL type S). J37? 3.7L is pushing it....don't you think? But at the expense of doing these swaps...it's like buying another v6.
Old Jun 30, 2008 | 06:16 PM
00AccordGuy's Avatar
you can get a f23 to 300hp with an NA bulid itll cost a ton but has been done. look on 6thgenaccord.com
Old Jun 30, 2008 | 07:56 PM
Thanks for the answers....
Looks like J35 or J37 will be the engine I use.
Old Jun 30, 2008 | 08:51 PM
  #17
03Sleeper's Avatar
J37 is gonna be hard to find (junkyards, local places)....its debut is in the MDX (i think)...if you wanna swap a J37 give it some time and some poor bloke is gonna crash his MDX and trash it at the junkyard...then make your move.
J35 is more likely to be found
Old Jul 1, 2008 | 08:45 AM
  #18
falkore24's Avatar
J35 can be found in the Saturn Vue Redline!!!
Old Jul 1, 2008 | 08:46 AM
  #19
03Sleeper's Avatar
No way....seriously?
Old Jul 1, 2008 | 09:00 PM
  #20
HORSEPOWERJUNKIE2007's Avatar
you might as well drop the J32 in.
