MOdifying an intake Manifold??
Old Sep 10, 2008 | 08:19 PM
  #41
Default RE: MOdifying an intake Manifold??
ORIGINAL: clutch811
wow thats not very much lol. ill trade ya. this brings up another question if youre familiar. i need a new clutch probly gonna happen this summer. can i get an aluminum flywheel, will it be ok to use and will it make a difference? dang! if i had enough money id just get an h22 and have it installed since theyre gonna have to tear into the drivetrain anyway.
yeah thats a rough estimate, in my brief search i couldnt find a dyno of a f22b2, but a b1 with some bolt ons made 116whp.
i have a aluminum flywheel........8.8lb. yes it makes a differance, the engine revs much quicker, however makes down shifting useless and you have less time to shift before the rpms drop. just a few down sides to keep in mind. obviously with the lighter the flywheel the worse the bad gets and the better the good gets.
H22s arent that much, you can get a long block for around 1k.
Old Sep 10, 2008 | 08:25 PM
  #42
clutch811's Avatar
wait just the block or the whole motor, and are there shorts available?
Old Sep 10, 2008 | 08:28 PM
  #43
long block is block head usually intake manifold and exhaust manifold.
short block is just the block thats it. those are harder to find, but idk why you would want one, the head is where you make most of the power
Old Sep 10, 2008 | 08:37 PM
  #44
clutch811's Avatar
haha sorry im confusing myself. i actually know that. as for why id want a short, could it be cheaper to get things separate and build it up. like h22 head then get a header and skunk2 intake w/o having to pay for the stock manifolds i guess.
now as you mentioned about the flywheel, why is down shift useless on the lighter, high revs but falling faster i can understand hence inertia(there's less of it)
Old Sep 10, 2008 | 08:39 PM
  #45
nah i would say if anything it would be more money to do that, i mean stock manifolds arent really worth that much.
back to the inertia again.........doesnt have inertia to slow it down, you down **** and you are just at a higher rpm and dont really slow down.
Old Sep 10, 2008 | 08:44 PM
  #46
clutch811's Avatar
hmm ill try something in between then, if they have it. as for the engine swap how hard is it to do. is it bolt in or are there required mods?
Old Sep 10, 2008 | 08:47 PM
  #47
there are a few minor mods, either modify the stock motor mount or buy a hasport one, then a few wiring mods but thats it
Old Sep 10, 2008 | 08:59 PM
  #48
clutch811's Avatar
maybe if i blow this motor i got(unintentionally) i can convince my dad/mom to let me get one to replace it lol
Old Oct 11, 2008 | 03:56 PM
  #49
clutch811's Avatar
well today i got some time and dug into the manifold and cleaned it a little. its amazing the gunk and dirt that build up in these things. question. is it possible and worth it to bypass the egr valve on the manifold?
Old Oct 11, 2008 | 04:28 PM
  #50
very possible, most people just put a plate in that blocks it. My Skunk2 manifold doesnt even make it a option to run a EGR valve.
