mounts problem with H22A swap
Old Mar 20, 2006 | 07:31 PM
boots's Avatar
Default mounts problem with H22A swap
yeah I just swapped my H22A engine into my 94 EX, I bought the hasport mount and Im running into a problem with it linning up, I called hasport and they said use all prelude mounts, I thought I heard to use the accord mounts, I have all accord mounts on there and the engine sits about 1-2in's forward on the driver-side, just wanted to make sure I am correct about using all prelude mounts before I go and buy the front and rear prelude mounts, I already have the passenger side prelude mount. So can anyone help? Thanks Dakota
Old Mar 20, 2006 | 08:52 PM
marbro's Avatar
Default RE: mounts problem with H22A swap
For most of what ive read its suppose to be all the prelude mounts
Old Mar 21, 2006 | 01:22 AM
boots's Avatar
Ok thanks for the help, I just wanted to make sure before I just go buy the front and rear prelude mounts. I just hope that fixes the problem. Thanks Dakota
Old Mar 22, 2006 | 10:04 PM
boots's Avatar
Hey, just wanted to make sure before I go ahead and order these mounts, will this fix my problem? I had all accord mounts on there, I just put a prelude mount on the transmission side to see if it would fix the problem but it didn't, so I have accord front and rear mounts, on prelude brackets, if I buy the prelude front and rear mounts, will they line my h22 up right so I can bolt my hasport mount on and have the engine in right? I just don't want to wast $112 on new mounts if they won't help. Thanks Dakota
mpanelli
Nov 9, 2014 08:39 AM
VTECSK8R88
May 15, 2009 01:30 AM
hitek85
Feb 12, 2008 10:32 AM
pr3z
Jan 13, 2007 03:06 AM
zelseman
Jan 19, 2006 05:57 PM
