My engine is leaking oil, need help asap
Old Aug 17, 2006 | 03:36 AM
chevync20's Avatar
Default My engine is leaking oil, need help asap
I just recently purchased a 1990 Honda Accord LX that I bought to drive back and fourth to work and after only 300 miles it seems to have a serious oil leak and need help. I just replaced the oil plug and filter and was hoping that would help, but to no avail. It appears to be leaking right above the oil pan right where the bottom pully is, i assume this is the timing belt housing. There is oil seeping down from in there, what could this be? Seal on the crank? Please someone help me so when i take it to the shop they dont run around and tell me its something else.
Old Aug 17, 2006 | 04:13 AM
lightshow's Avatar
Default RE: My engine is leaking oil, need help asap
yea if its coming from there its the seals in there. get them fixed quick and make sure they put the special retainer in there. you can easily ruin the motor if the seal pops out, which it sounds like it did. dont drive the car anymore have it towed
Old Aug 17, 2006 | 07:27 AM
YeuEmMaiMai's Avatar
change the timing belt and have then replace the balace shalft seal and install the retainter kit for it
Old Aug 17, 2006 | 01:25 PM
HondaRacer4Vtec's Avatar
just curoius how many miles on the car?
Old Aug 17, 2006 | 03:33 PM
chevync20's Avatar
190k but the previous owner told me he had it changed in the last 5000 miles, but they might not have replaced the seals, so i quess to the Honda shop it goes
Old Aug 17, 2006 | 04:56 PM
lightshow's Avatar
no they might not have put the retainer in there. problem is now that the oil has probably splashed on the timing belt which will reduce its lifespan considerably.
Old Aug 17, 2006 | 07:04 PM
mbo1985's Avatar
Yeah, you don't want to mess around with thtat belt. If it has been exposed to oil, i'd say you're better off replacing it.
Old Aug 18, 2006 | 03:42 AM
chevync20's Avatar
I think im just gonna get the whole service done to be on the safe side. I would feel more comfortable knowing all of that will be good for years to come. I will let you guys know what it is when they tear into it on monday
brandyn
Nov 26, 2013 05:31 PM
hatemydadsaccord
Oct 2, 2012 12:13 PM
Joshneuen
Jul 24, 2011 06:51 PM
firechicken
Feb 2, 2010 03:20 PM
pji84
Jan 27, 2006 07:03 AM
