need advice on f22
Old Aug 3, 2006 | 04:24 PM
killrmack
Default need advice on f22
HI I HAVE A 92 WGN AND I NEED SOME HELP. I WANT TO EVENTUALLY TURBO THE MOTOR AND I NEED TO KNOW WHAT NEEDS TO BE UPGRADED MOTOR INTERNALS WISE IT HAS ALOT OF MILES (PULLED BY AN RV) BUT RUNS LIKE A CHARM. IVE READ THROUGH SOME OF THE TOPICS ABOUT THE F22 BUT STILL I COULD US SOME INFO. THANX MUCH
Old Aug 3, 2006 | 04:47 PM
sir_nasty's Avatar
Default RE: need advice on f22
mbo1985 and marbaro both have turbo'd f22's (I believe they are f22's anyway...) look through the search for turbo help... basically they installed a turbo with 8psi of boost on an engine with 145k miles so the internals should handle at least 8 psi in their stock condition... If you want to re-do the internals check out f22parts.com they seem like a good group of guys, you can also over bore your engine to 87mm and put in prelude pistons if you wanted then turbo it.... so you've got options but to start out with I'd just put it on and keep the boost low
Old Aug 3, 2006 | 05:20 PM
killrmack
THANKS
Old Aug 3, 2006 | 07:51 PM
marbro's Avatar
hehe, not quite turboed, but close..... very close.... ive been drooling over the parts for the last month, but i still need one more and lack the money to get it. But i have an f23, mbo is the one with the f22 so, he will have more run time experience then i do
Old Aug 3, 2006 | 08:21 PM
lightshow's Avatar
ive got a 91 wgn. 260 thousand miles on it. nothing needs to be done internally to turbo your car.
Old Aug 4, 2006 | 12:50 AM
mbo1985's Avatar
yeah, you seriously don't need to mess with anything inside the motor if you want a low boost (8 psi or less) set up. And your car will RIP!!
Old Aug 4, 2006 | 12:07 PM
killrmack
MBO DID YOU PICE YOUR SYSTEM TO GETHER OR DID YOU BY A KIT.
Old Aug 4, 2006 | 03:51 PM
sir_nasty's Avatar
The supreme post about mbo's turbo building spree....
https://www.hondaaccordforum.com/m_9882/tm.htm
read through that and it's got a TON of information about almost everything you need to know
Old Aug 4, 2006 | 08:24 PM
mbo1985's Avatar
ahhh the memories.
After reading that I gaurentee you won't screw up installing the FMU!!
maverick2k7
Feb 5, 2011 08:59 PM
AbaZ
18
Jul 16, 2008 10:23 PM
SpanishN00b
Jul 29, 2007 07:11 PM
Hondamatic
Apr 20, 2006 03:41 PM
