need flywheel help
Old Feb 10, 2008 | 07:30 PM
accrd94ex's Avatar
Default need flywheel help
Ok i just had my flywheel and clutch installed and my car doesn't accelerate like it use to i put a 11.9 pound flywheel in from the stock 21.9 pound flywheel and a exedy oem replacement clutch. It just doesn't take off for POO is it that the clutch needs to break in or do you think there is something wrong like when i take of just like a noraml person it feels fine but when i go to get in it it just doesn't do anything i need to replace the speed sensor cables on the trans because the odomoter doesn't work could that be the problem i really need this fixed
Old Feb 10, 2008 | 07:52 PM
JohnL's Avatar
Default RE: need flywheel help
Is the clutch slipping?
Old Feb 11, 2008 | 01:20 PM
accrd94ex's Avatar
no the clutch isn't slipping i found out that v-tec will not work right with out the VSS working so i fixed the wires that came out of the sensor and now it is about 25% faster than it was. The new flywheel helps out alot
SKHEMR
Feb 3, 2020 11:27 PM
GSXRAccordH22
Jun 14, 2012 06:06 PM
kapital
Jun 12, 2008 04:43 PM
yamahonda06
Apr 13, 2006 01:19 PM
karls
Feb 7, 2006 06:05 AM
