Need to Raise my Cars Idle
Old Jun 14, 2007 | 10:50 AM
sUbLiMe96's Avatar
Default Need to Raise my Cars Idle
Does Anyone know how I can Raise my idle..... When Im in Neutral like at a stop light the car almost shuts off due from such a Low idle....I would like the car to always idle high around 1000rpm.
Oh, i have a 96 non-vtech F22
Old Jun 14, 2007 | 11:27 AM
gliff159's Avatar
Default RE: Need to Raise my Cars Idle
push on the gas while in netural
Old Jun 14, 2007 | 02:09 PM
deserthonda's Avatar
turn the adjuster screw on the throttle body counterclock wise ( assuming everything is ok ) it should raise the idle up ..Do not raise idle to high or engine will surge
Old Jun 22, 2007 | 11:55 AM
sUbLiMe96's Avatar
What does it mean to surge?
Old Jun 23, 2007 | 09:28 PM
Surging idle is when the idle doesn't stay constant but it goes up & down. Maybe 600 to 1500 over & over.
Why do you want it to idle high? 750 or 800 is where it should be. If you set it up to 1000 the idle control system might start fighting with it & that's what causes the surging.
Old Jun 24, 2007 | 01:01 PM
03Sleeper's Avatar
Yeah...my idle dips down to 900...and I have a 7th gen.
Old Jun 26, 2007 | 11:11 AM
sUbLiMe96's Avatar
Yeah,,,,I would like my idle around 800-1000.... right now when im at a stop light it dips and stays down at a Lousy 500-575 rpm...I just want a normal or slightly higher than normal idle...I have AEM pulley kit which i have been told may be a reason....I wish to keep my pulleys but want a higher idle too...
Old Jun 26, 2007 | 12:09 PM
You might try setting your 'BASE' idle properly (I don't know what rpm), then resetting your ECU & letting it re-learn the idle.
Search for 'base idle' because I think I've written about it before.
Old Jun 26, 2007 | 03:04 PM
sUbLiMe96's Avatar
UMMMM? Can i do that with a Greddy Engine Management system,,,,I ditched the stock ECU..?
[IMG]local://upfiles/10481/FF66710E6A8E4C108BE3EED09273E006.jpg[/IMG]
Old Jun 26, 2007 | 11:23 PM
I don't know. If it mimics stock but allows you to reprogram, you might be able to set the operating idle.
The base idle is low, like 500 or 600, when the IACV is unplugged.
Then you reset the ECU and let it relearn the idle control. A stock ECU will learn the behavior of the idle system by starting it & letting it warm up all without touching the gas pedal at all. If the Greddy ECU maintains that capability, then let it do it's thing.
Toltepequense
Sep 12, 2011 08:59 PM
stillearning
Feb 28, 2011 09:35 AM
frankie ruiz
May 27, 2010 09:33 AM
01Accord01
Apr 26, 2010 09:08 PM
R.Accord
Dec 25, 2009 01:52 PM
