NEED RECOMMENDATION
Old Jul 12, 2006 | 12:10 AM
isuboy's Avatar
Default NEED RECOMMENDATION
I AM THINKING TO CHANGE MY SPARK PLUGS AND ALL THE SPARK PLUG WIRES ...AND MAY BE DISTRIBUTOR CAP IF THAT HELPS IMPORVE PERFORMANCE
ANY RECOMMENDATION ON SPARK PLUGS AND WIRES AND CAP ......WHAT I AM LOOKING FOR GOOD QUIALITY STUFF IN REASONABLE PRICE ......AND ALSO WHICH STORE DO U RECOMMEND TO BUY THOSE FROM ???????
THANKS
Old Jul 12, 2006 | 12:17 AM
YeuEmMaiMai's Avatar
Default RE: NEED RECOMMENDATION
stock replacement for everything that you listed
Old Jul 12, 2006 | 01:20 AM
tom15425's Avatar
Yep, I'd stick with stock plug wires and alot of good people here will tell you ngk plugs are the way to go. I personally have not tried them, but when I get around to it I'm putting some in. As far as performance, the only hp increase you'll notice is if you've already lost some due to problems with the parts your planning to replace.
Old Jul 12, 2006 | 01:27 AM
mbo1985's Avatar
NGK plugs are highly rated around here... Should be OEM stuff there.
And stay away from bosch plugs!
Old Jul 12, 2006 | 04:55 AM
deserthonda's Avatar
I agree with the other members,,,,,,,,,,stick with Honda factory parts.. get the parts at the local Honda dealer you might pay a bit more but considering how long they will last your car will love you ..
Old Jul 12, 2006 | 10:09 PM
You can find NGK plugs at lots of places, I don't know if you'll save much money vs. the dealer.
Dealer cap, rotor, & plug wires are good. Aftermarket versions of that stuff isn't going to give you any power increase if that's the only thing you change. If you notice more power, it's because that stuff was old & bad before you replaced it.
tradosaurus
Sep 28, 2011 10:04 AM
blksniper2000
Aug 24, 2007 06:05 PM
heffus
Oct 18, 2006 03:24 AM
longhornjohn
May 31, 2006 12:02 AM
longhornjohn
May 19, 2006 09:23 PM
