Need to rotate the engine
Old Aug 26, 2005 | 05:34 PM
mach1engines
Default Need to rotate the engine
Just bought an old 85 Accord. with an auto. Guy I bought it from said it was the starter, replaced that. But then i realized that it was actually the gear that the starter turns. How do I rotate the engine, so I can get past the part on the gear that is grinded down? Just started getting into hondas, mostly know v8s. Thanks a bunch
Old Aug 27, 2005 | 05:19 PM
Default RE: Need to rotate the engine
Hi New Member..
I have a ? for you ..
Why are you trying to get past the part on the Flywheel where your gear may be damaged, take the starter off and inspect with a flash light if you can get in that close..
ndnz
Feb 1, 2014 07:51 PM
brandyn
Nov 26, 2013 05:31 PM
Kukukachoo
Feb 5, 2013 06:42 AM
ndp
Jun 21, 2007 04:30 PM
brave_mhy
Jul 17, 2006 01:37 AM
