No MAP sensor?? Bad??
I own a 90 accord with 96 F22b1 vtec engine, but i've noticed that it doens't have Map Sensor. Is that bad to have? I cant find out where its connected to. I just want tknow if its bad not to have a map sensor
reply me back if you guys can . Thanks
you should have a check engine light then (which, to answer the question at hand, would be Yes, that's bad). Are you sure it's not on the intake manifold right after the throttle body? It doesn't look like a MAF at all (and it's not right after the filter box)
marodmotorsport
Aug 2, 2007 10:23 PM
