No MAP sensor?? Bad??
Old Sep 8, 2006 | 05:03 PM
Nightrider
Default No MAP sensor?? Bad??
I own a 90 accord with 96 F22b1 vtec engine, but i've noticed that it doens't have Map Sensor. Is that bad to have? I cant find out where its connected to. I just want tknow if its bad not to have a map sensor
reply me back if you guys can . Thanks
Old Sep 8, 2006 | 06:35 PM
mbo1985's Avatar
Default RE: No MAP sensor?? Bad??
you should have a check engine light then (which, to answer the question at hand, would be Yes, that's bad). Are you sure it's not on the intake manifold right after the throttle body? It doesn't look like a MAF at all (and it's not right after the filter box)
Old Sep 8, 2006 | 06:51 PM
Nightrider
It is on the intake manifold after the throttle body. My check engine light is never on. On there it just has a slot to put in a sensor thats it, it said Sensor assy,MAP. and its right after the throttle body.
Old Sep 8, 2006 | 06:53 PM
Nightrider
on it,it said, Sensor assy, MAP and i have no idea what the heck that means.
d_10
Aug 16, 2014 07:49 AM
ajshep
Nov 10, 2013 11:10 PM
giulio76
Dec 29, 2012 11:16 AM
marodmotorsport
Aug 2, 2007 10:23 PM
Gabino
Sep 11, 2006 02:09 PM
