No start, no crank, no key light
Old May 15, 2022 | 04:22 PM
shanin's Avatar
Originally Posted by GHIBBS
Fixed! Thank you TexasHonda for the help you provided.If you run across this again, it is worth mentioning. I went back under the car, and found a grounding cable which was part of the wire harness was not connected. After connecting the ground. all the symptoms disappeared. The key light and check engine light came on when the key was turned to run position, and the shifter could now move, and the shift position lights came on, the fuel pump ran and the car started up without trouble. The key thing to remember about my problem is this was an engine replacement, so all wires and sensors were disconnected, and then hopefully reconnected. For most car problems, these things are undisturbed, so therefore not a part of the problem.
My grandson was helping put things together and recalled that he didn't think connecting the ground would be important-he is hearing about it from me.
Thanks again,
Gil
help…. Where exactly WAS that ground wire! Having similar issue after a 99-02 engine swap. I did find all grounds in the electrical repair manual, but none were underneath. Please let me know what ground wire you found.
csh217
Jun 17, 2014 05:53 PM
corlyf
Sep 12, 2012 11:30 PM
huhdo
Aug 30, 2012 09:06 PM
dcovarrubias90
Aug 18, 2012 12:40 AM
wietgr
Jun 13, 2007 06:41 PM
