Rebuilt 2.2 no start
Old Jun 12, 2011 | 01:45 AM
Hoosier's Avatar
Default Rebuilt 2.2 no start
Howdy. 95 Accord EX 2.2 VTEC
Engine was operable, but bad transmission
Replaced transmission. Rebuilt most of engine, new bearings, seals, gaskets, head gasket, belts, etc. Naturally had to reset timing. I don't have a book, but I think it's correct. Turned engine over to ensure no piston/valve interference. Reinstalled engine.
The car turns over but will not start. There is no spark at the plugs, and I don't think the fuel pump is running.
In other vehicles, that would make me think the crankshaft position sensor had not been reconnected. In the Accord, I don't see a CPS, but maybe internal ?
I would be grateful for suggestions for what may be the cause.
Nothing off the table. I have looked for disconnected wiring. I don't see any, but I don't discount the possibility.
Thank you
Old Jun 12, 2011 | 06:16 AM
piggylover1985's Avatar
Not sure about 95, but the CPS is locate next to the crank gear behind the crank pulley in my 99 and the connector is on the outside of the timing belt cover, where both pieces of the cover joint together on the backside.
Old Jun 12, 2011 | 09:04 AM
Hoosier's Avatar
Default CPS in distributor assembly
I just read elsewhere that the CPS is in the distributor assembly. That would explain why I couldn't see any wiring for it around the crankshaft front end.
I don't know. Maybe my timing is wrong.
Old Jun 12, 2011 | 10:32 AM
Check the ground on the end of the TB (drivers side)...this is the main ground for the ecu, if it is not on and secure the ECM will not fire the dist or injectors.....
Old Jun 15, 2011 | 12:01 AM
Hoosier's Avatar
Default what is TB ?
Poorman, what is the abbreviation TB ?
Stark
Old Jun 15, 2011 | 05:53 PM
Tek310's Avatar
throttlebody
Old Jun 16, 2011 | 07:08 AM
See if this helps in finding it
Old Jun 19, 2011 | 09:19 PM
On 1995, the CKP sensor is inside the distributor (along with the TDC & CYP sensors). A couple years later they moved it to the front cover & changed around the timing-sensor scheme.
Old Jun 19, 2011 | 11:19 PM
Hoosier's Avatar
Default issue resolved
Thanks to all replies, but especially thanks to Poorman !
The issue was indeed an improperly grounded computer. That and the distributor was 180 degrees out.
Stark
Old Jun 20, 2011 | 12:16 AM
HowdysAutoRI's Avatar
hmm have you tried looking at the distributor cap. maybe its dead? or maybe even the timing of the car? run a compression test to make sure your timing is not off
Auto Repair RI
-howdy
nocturnal
Jul 23, 2008 02:27 PM
Tomtn2008
Feb 21, 2008 11:38 AM
mck52689
Jul 26, 2007 10:14 PM
ckebottle
Oct 30, 2006 03:50 AM
ballistic
Aug 26, 2006 01:25 PM
