replace engine 98Accord Vtech 4cylinder
Old Mar 4, 2007 | 09:09 PM
FLHonda98
Default replace engine 98Accord Vtech 4cylinder
Hi
You may or may not have read my adventure with the lower PULLEY BOLT LOOSE and the timing pully slipping. In any case, the Honda dealer is putting in a used engine in the 98Accord LX Vtech-4cylinder (from a registered recycle company). The used engine has 71K miles. What would you have them do before they drop the replacment into the car, if you were paying the Honda dealer to do it.I appreciate your experience. Thank You
Old Mar 4, 2007 | 10:07 PM
lightshow's Avatar
Default RE: replace engine 98Accord Vtech 4cylinder
i would do new plugs wires dist cap rotor. belts including timing belt and water pump
Old Mar 4, 2007 | 11:38 PM
deserthonda's Avatar
for sure t-belt and water pump.and all the seals under the timing cover . also a new REAR MAIN seal..
new t-stat,,,,, if coolant hoses on your car need to be replaced this is a very good time to do them.
localstoner
Oct 25, 2013 05:56 PM
firefunk
Nov 27, 2011 02:15 PM
thull000
Jun 9, 2011 09:40 AM
Mpwr
May 11, 2006 07:51 PM
