'98accord: Headlight is out but if you bang on headlight plastic it comes on??
Old Nov 1, 2006 | 03:41 PM
djstylze
Default '98accord: Headlight is out but if you bang on headlight plastic it comes on??
So this is a strange problem.
Its a 4door 1998 honda accord, and the passenger headlight is out. If you bang on the plastic light assembly, it comes back on. This is so crazy I had to see it for myself. I looked at the contacts on the headlight and the wiring harness, but nothing is corroded. We haven't tried changing headlights yet because the light will work for the rest of the day.
I would love to hear ideas why its doing that..
Thanks guys!
Mike
Old Nov 1, 2006 | 06:56 PM
Default RE: '98accord: Headlight is out but if you bang on headlight plastic it comes on??
I would have to say that there is a short in the wires or in the socket itself..clean off the connecters and the headlight plug and see if thi stops the problem..also check the ground wire from the headlight to the body.
Old Nov 1, 2006 | 07:28 PM
djstylze
Where does the ground come off the headlight assembly? I figured all the wires are part of the harness itself?
Old Nov 1, 2006 | 09:33 PM
sir_nasty's Avatar
swap the bulb from the passenger side to the drivers side, if the drivers side starts doing it then you know what's wrong, if it's still the passenger side then inspect the harness very carefully, make sure the contacts don't have a problem...
Old Nov 2, 2006 | 03:01 AM
deserthonda's Avatar
try a different bulb
Old Nov 2, 2006 | 01:20 PM
djstylze
Thanks for the help guys. That was my first thought and it was just odd that you could bang the plastic to make the light work again.
Old Nov 2, 2006 | 02:08 PM
YeuEmMaiMai's Avatar
headlight housing is made from acrilic and abs platic...you cannot use it as a ground...most likely just like the others said, change the bulb...there is a loose connection and when you whack it, it starts to work.......
valerie
Jun 26, 2010 09:20 PM
JPX
Feb 13, 2009 06:29 PM
rtmobile96
Oct 1, 2007 10:51 AM
FLHonda98
Mar 4, 2007 11:38 PM
GodMachine
May 14, 2006 12:27 AM
