Ringlands strength
Old Jul 25, 2010 | 05:16 PM
g22cd5's Avatar
Supper Moderator
Default Ringlands strength
Ok well I’m at the point I need to know what I want to do about pistons. IF I can get away with the OEM f22 ones that would be great...but I want to have so reliability backing up this power goal I have in mind (400+)
Now I know the h22 pistons have weak ring lands...so how about the f22s? I see ppl boostin the crap out of them all the time but how long should they last at high boost? Would it be the best bet to just fork over the 500bucks and go forged?? btw this will be a g22 vatack
Old Jul 26, 2010 | 05:42 AM
g22cd5's Avatar
Supper Moderator
wow really? I figured Jim or Rice would have popped in to say hi...
btw I'm hearing both sides of the story on this they are weak and then hey aren’t weak.,..ugggh I just want a solid answer
Old Jul 26, 2010 | 05:39 PM
You mean ME?
I understand the engineering behind it, but I don't know the specifics of F22 vs H22 pistons. So I don't really know the answer.
Old Jul 26, 2010 | 06:54 PM
g22cd5's Avatar
Supper Moderator
Originally Posted by JimBlake
You mean ME?
lol yeah you
Do you know what causes a ringland(s) blows out or breaks?...
Old Jul 26, 2010 | 09:16 PM
One common thing is when break-in doesn't include any high-RPM work. The cylinder walls wear & the ridge develops at the top of the cylinders. Then at high RPM the rods "stretch" & the ring slams into the ridge.
I don't know if it's very common for ringlands to break just under the increased combustion pressure with boost. I'm an engineer, but not in the automotive world. I don't know what kind of margins are common for the piston structure, but I bet the margins are getting more & more slim as each company tries to out-perform the others.
Some modern engines make things worse by having very shallow piston skirts. Plus the rings are getting much closer to the top. On one hand that's good because there's less dead space between the pistion crown & the first ring. Lighter pistons = less reciprocating mass. OTOH the piston is a less robust structure.
Trade-offs are everywhere in life. You can make your car nearly indestructable by stamping the body out of 1/4" steel plate. But then the car would weigh about 36,000 lb.
