Rough idle on warm startup
Old May 27, 2015 | 09:29 AM
BlackLX4's Avatar
Default Rough idle on warm startup
This has probably been covered plenty of times already, but I have a warm startup issue. It happens pretty regularly (at least every second warm start). What's happening is that when the car has been running and then has been turned off for a little while, I start it up again with the engine still warm and it misfires until I blip the gas a time or two, and then it's just fine. No other running issues. Excess fuel? Vapor lock?
Old May 28, 2015 | 05:50 PM
Sorry but I have to ask about the simple things first.
No stored codes, tune up items related to ign system are up to date (cap, rotor, plugs, inspect wires)?
Old May 28, 2015 | 09:47 PM
BlackLX4's Avatar
No, you're fine. Cap, rotor, wires and plugs are all new. The only stored code is the P0420 (catalytic converter system).
Old May 30, 2015 | 10:01 AM
Humm, nothing reall comes to mind as a "known/likely" issue on a 6th gen four cyl
I could "guess" at a hundred things but that would help anything but to empty your bank account......
Nalnin
Jun 28, 2015 08:16 PM
sis00accord
Dec 19, 2011 12:27 AM
longtimeowner
Sep 28, 2011 11:33 AM
stangmanx
Oct 1, 2008 01:04 PM
Jason29
Jan 17, 2007 12:58 AM
