Rough idling 2003 Honda accord 4cyl manual
Old Dec 31, 2024 | 06:13 PM
Tdblaschke's Avatar
Default Rough idling 2003 Honda accord 4cyl manual
Anyone have any ideas what is causing this at idle? Already replaced the iac valve. This is a 2003 5 speed manual coupe. Threw a P0507 code and the car is catless if that matters, also when i drive it and go to shift while its doing that bouncing the rpms drop drastically when i push in the clutch to shift it is not the normal gradual fall. I cleaned the entire throttle body when the issue first arose, but it persisted, so I replaced the throttle body gasket and the iac valve. However, not only did the issue recur, it got worse. Initially, it was just sporadic surges while idling, but now it happens whenever I am in neutral idling for a short while, but it will go away when I restart the car. I haven't tested this thoroughly, but it doesn't appear to occur when I am in gear stopped.
File Type: mov
bobbiesoxer28
Jul 16, 2023 11:53 AM
Lauren
Oct 17, 2013 07:12 PM
legoses
Jul 4, 2011 06:27 PM
Sheryl S
Oct 26, 2009 07:19 AM
TRDZNTZ
Jul 8, 2009 06:35 PM
