RPM's going up and down at idle
Old Feb 12, 2012 | 06:37 PM
drawk04's Avatar
Default RPM's going up and down at idle
Recently, my car has began acting a bit strange at idle. When the engine is warm, the rpm's go up to about 1800 and back down to 1000 or so over and over. I took off the idle controller and cleaned it out, reinstalled it, and nothing changed. Perhaps its faulty ? I've heard this is a problem with honda's, my toyota I had awhile back did the same thing but it eventually quit. Any input ?
Old Feb 12, 2012 | 07:27 PM
rgr 96 monstro's Avatar
Adjust ur fit valve is under the throttle body has a brass cover open it hand tighten it all the way that's it it should fix ur issue
Old Feb 12, 2012 | 09:17 PM
drawk04's Avatar
cant seem to find it, could you describe it a little better or direct me to a photo ? do I need to take anything apart to access it ?
Old Feb 12, 2012 | 10:08 PM
drawk04's Avatar
I found it but there is nothing to adjust on it...
Old Feb 12, 2012 | 11:17 PM
drawk04's Avatar
So....adjusted that ring, tightened it down, cleaned that and the Idle Controller....the problems purist.
Old Feb 13, 2012 | 12:07 AM
My bad its easier if u remove the throttle body its right under it remove it clean the throttle body really good. Then remove iacv and same thing u clean it let them dry up that's wat I did to mine and it fix the issue
Old Feb 13, 2012 | 05:53 PM
drawk04's Avatar
Just replaced both...and the coolant temperature sensor...problem is still there.
Old Feb 14, 2012 | 07:56 AM
Have u tried bleeding ur coolant lines their is a bleeder in the thermostat housing if u open it slowly air will come out do it until coolant comes out then check make sure is leveled
Old Feb 14, 2012 | 10:03 AM
crispin's Avatar
mine started surging the same as yours and bleeding the air from the coolant system fixed it
Old Feb 15, 2012 | 03:41 PM
drawk04's Avatar
alright....had it confirmed its a bad intake mani gasket...not a big deal but enough to disappoint me....and yes, i bled the cooling system.
