S2000 head swap
Old Jul 23, 2007 | 10:57 PM
stefanb21487's Avatar
Default S2000 head swap
has any one heard of an S2000 head swap to a F23 ( accord 98-00)
Old Jul 24, 2007 | 12:21 AM
stevent's Avatar
Default RE: S2000 head swap
not that I heard of, I heard of the g23 swap though.
Old Jul 26, 2007 | 08:28 AM
finch13's Avatar
The S2000 is running a K-series motor I believe and I'm sure if you swapped it with another K-series motor you'd see some gains, but I'm not sure if you'd get good results with an F23.
Old Jul 26, 2007 | 08:37 AM
marbro's Avatar
g23 = h23/22 head swap, i dont think you can swap k series heads to f series
Old Jul 26, 2007 | 09:54 AM
Velocifero's Avatar
ORIGINAL: finch13
actually, the S2000 has the F20C motor.
Old Jul 26, 2007 | 10:02 AM
finch13's Avatar
You're right, I don't know why I completely blanked on something I knew.
Old Jul 26, 2007 | 11:08 AM
leadfoot
anyone done this on a k-series or a 03 or newer motor i was thinking of doing itand since the topic here i thought i would ask.
Old Jul 26, 2007 | 11:38 AM
stevent's Avatar
i doubt that the k series would fit onto an f series.
Old Jul 26, 2007 | 11:50 AM
finch13's Avatar
If it is even possible I would check the "Hybrids" forum over at honda-acura.net. And if you become serious about it, check out forum.pgmfi.org. They might have some info for you, but they are mostly OBD1 stuff.
Old Jul 26, 2007 | 06:00 PM
legionofone's Avatar
ok this is how it works... the F20/22C! is the older brother of the K series... it doesent have the I-Vtec but it is very similar to the K block and head... the head is UNIQUE to the F20/22C and cannot be swaped to or from any other block... not even other F series (as its not a normal F series it realy should of been called a S series since it is only found in the S2000 and no where else) the NEW S2000 (rumored to be called the S800) will be a RWD K series... EVERY S2000 in existance runs a F20/22C block get a F20B head from a euro accord and be done with it
petef23a
Aug 12, 2009 07:34 PM
thunder_x
May 12, 2008 05:09 PM
leviathann
Feb 28, 2008 09:53 PM
mrbobolonian
Jan 12, 2008 09:54 AM
superpimp12
Mar 27, 2005 12:55 AM
