should this prepare my old engine for performance?
Old Apr 26, 2007 | 04:29 PM
noboundaries6289's Avatar
Default should this prepare my old engine for performance?
hey all, I'm thinking of replacing my timing belt, balance shaft belt, alternator belt, power steering belt, all tensioners and tensioner springs, and my water pump. Labor for all is $400. Parts, around $300-$350.
Is doing a job like this worth it? I'm trying to put an intake and exhaust on it and travel into the 4-5k RPM range more often. Also, how long will this extend my engine life? thanx
Old Apr 26, 2007 | 05:45 PM
incountry's Avatar
Default RE: should this prepare my old engine for performance?
why are you replacing the tensioners and springs, also I dont see any seals listed
Old Apr 26, 2007 | 05:53 PM
I heard some people say they put new belts on, then tensioners let go and engine blew. Also, i forgot to mention, the only seal I'm thinking of getting would be the camshaft seal. Other than that, my funds are very limited. What do you reccommend to replace?
Old Apr 26, 2007 | 06:02 PM
incountry's Avatar
I have 387,000 on my accord and I have never replaced the tensioners, the most critical seal is the balance shaft seal, but for less than 25.00 i would replace all of them including the oil pump o-ring
Old Apr 26, 2007 | 06:04 PM
incountry's Avatar
I worked at a honda dealer for over 8 years as the shop counter parts person and I think I probally sold may 5 tensioners in that time, If the belts are done right you shouldn't have any problems.
Old Apr 26, 2007 | 07:55 PM
sir_nasty's Avatar
If you've got the tensioners then you might as well replace them but if you haven't bought them yet then don't and just use the money for seals
Old Apr 27, 2007 | 12:49 AM
what seals should I replace and how much is labor gonna run me? Timing belt and balance shaft belt for install run me around $200-$250. How much more are seals gonna run? thanx
Old Apr 29, 2007 | 05:57 AM
c'mon, someone respond ....please.
Old Apr 29, 2007 | 04:18 PM
ckebottle's Avatar
91233-PT0-003 BAL SHAFT SEAL 06923-P0A-306 BAL SHAFT SEAL RETAINER 15114-PT0-003 OIL DRIVE GEAR SEAL 91212-P0A-004 FRONT MAIN (CRANK) SEAL 91213-PT0-003 CAM SEAL 12341-P0A-000 VALVE COVER GASKET 12342-P2F-A01 SPARK PLUG TUBE SEALS X 4
Old Apr 29, 2007 | 09:16 PM
thanx for the info, i priced everything at around $40. Installation will probably be a couple more zero's lol.
