should this prepare my old engine for performance?
Old Apr 30, 2007 | 04:22 AM
ckebottle's Avatar
Default RE: should this prepare my old engine for performance?
If you go to majestichonda, i got all those seals, the timnig belt, balancer belt and water pump for 166 shipped. Might want to check them out.
Old Apr 30, 2007 | 01:39 PM
noboundaries6289's Avatar
I have goodyear gatorbacks for the timing belt and balance shaft belts. just need water pump and gaskets.
Old May 1, 2007 | 06:44 PM
are these all the things I need for a 90k x2 (180,000miles) tune up? just timing belts, balancer belts, water pump, and whats listed above? I got a mechanic that says he can do everything for $257. do I need anything else?
Old May 1, 2007 | 07:52 PM
ckebottle's Avatar
That should be complete. Is the mechanic also going to do a valve adjustment?
Old May 1, 2007 | 08:46 PM
sir_nasty's Avatar
if he'll do the valve adjustment at the same time you may need a new valve cover gasket....
probably not, just installation. After all this, maybe i'll get an intake or exhaust system or something.
One Legged Eagle
May 10, 2014 12:37 PM
Jan 1, 2013 10:29 AM
UmidjOn222
Jun 10, 2010 10:26 PM
DA KID RYU
24
Mar 29, 2008 11:28 AM
kturnerga
Sep 25, 2006 05:13 PM
