smoke
Old Dec 2, 2008 | 10:21 AM
91hondalx
Default smoke
i just recently got a 91 honda accord lx. the problem i am having is on startup it pours out this white smoke. it does this until the car is warmed up say like five minutes or so then it clears up.the car does not run hot or anything. i checked the water its full i checked the oil and its full. and there doesnt appear to be any oil in with the water which would probably mean head gasket. its like a oil smell also i thought white smoke was coolant. any suggestions or help greatly appreciated. thank you daniel
Old Dec 2, 2008 | 05:07 PM
JohnL's Avatar
Default RE: smoke
In cool weather it's not unusual for steam to be produced at the end of the exhaust pipe, until the pipe heats up.I don't know what the smell is, but my bet is that it's unburnt fuel because the engine is in cold start mode where the ECU richens the mixture (quite a lot).
Old Dec 2, 2008 | 06:31 PM
91hondalx
Default RE: smoke
yeah i know its normal for some steam to come out but this is not steam this really bad white smoke. i was just curious if it could be the head gasket, valve stem seals or something else like i said it dont run hot or anything
Old Dec 4, 2008 | 04:42 PM
bmwproboi05's Avatar
Default RE: smoke
i have the same prob right now its coming from the hood. an i checked everything it sucked up all the water an the coolent up :/
Old Dec 4, 2008 | 06:09 PM
JohnL's Avatar
Default RE: smoke
If it's a leaking head gasket then the coolant level will fall sooner or later. With a cold engine check both the coolant level in the rad and in the overflow tank. You won't always get oil and coolant mixing with a leaking HG...
Old Dec 5, 2008 | 01:08 AM
skatingclaybird's Avatar
Default RE: smoke
Old Dec 5, 2008 | 11:27 AM
finch13's Avatar
Default RE: smoke
ORIGINAL: skatingclaybird
What does this mean? How is this helpful to anyone? Stop wasting our time and go do something productive with your life.
Old Dec 5, 2008 | 05:58 PM
91hondalx
Default RE: smoke
so does anybody else think they might know what would be making my accord smoke? would a 02 censor or something? i really dont know much about cars thats why im here.
Jtweaz
Nov 19, 2007 11:44 PM
jerz2stl
Jul 26, 2007 07:40 PM
metalmat
Jan 5, 2007 02:11 AM
sportsman1539
Jun 21, 2006 07:19 PM
Sliom001
Mar 28, 2006 06:57 PM
