Sport Button
Old Oct 27, 2005 | 09:38 PM
zelseman's Avatar
Default Sport Button
I have a 91 accord lx, with 207000 miles on it, and us recently, on occasion, the "Sport" button comes on without me pushing the button. Then after this happens ill let it sit for a day, and go out to start it and i have to give it gas to start it...I took the battery out today and went and got it tested, and the battery is fine, but when i put the battery back in it drove fine for about an hour. Any help is welcome.
Old Oct 27, 2005 | 11:17 PM
Evlampius's Avatar
Default RE: Sport Button
yeah - it is a transmission problem
i think we've discussed it here on forums - try to look for it in antique posts - I think you might fight some info
Tip of the day: Did you know batteries can be tested actually on the car?!?!
Added - just to cover the question - "Sport" on is sort of like a check engine light in the car - theres a testing procedure to get the code from Transmission of what went wrong and then repair accordingly. (try to find one of my posts on checking procedure)
Should you be worried?? ummm yes, just like any check engine light have to be treated in the short time
Old Oct 28, 2005 | 10:21 AM
Shocker's Avatar
The sport button is not a "check" light ..... it just gives u a better gear to gear ratio it has nothing to do with having proble,s or checking anything
Old Oct 28, 2005 | 10:15 PM
Evlampius's Avatar
ORIGINAL: Shocker
well then obviously you dont understand how transmission diagnostic codes work
Old Nov 11, 2005 | 02:39 AM
7thGen's Avatar
For starters the sport buttton is to give the drive a more agressive shift point with higher rev levels before shifting when the gas is held down. Generally the light only comes on when it is used. When the light flashes it can indicate transmission issues and even a bad speed sensor. When the light flashes does the speedometer bounce around or quit working? If so it may just be the speed sensor. If not you need to pull a transmission code as Evlamoius said.
cajundohboy
Feb 18, 2021 02:38 PM
suprarx7nut
Apr 1, 2007 10:57 PM
98_accord
Mar 24, 2007 08:36 PM
zelseman
Oct 29, 2005 09:10 AM
