starter replacement
Old Apr 7, 2006 | 08:10 PM
hnic514
Default starter replacement
could anybody tell me how to replace a starter on a 91 accord lx and were it would be in the engine bay
Old Apr 7, 2006 | 08:24 PM
sir_nasty's Avatar
Default RE: starter replacement
If you are facing the engine it will be on the left hand side there is usually 2-3 bolts holding it on. Disconnect all the wires going to it. Remove the bolts (typically one on top of it and one below it, on occasion there will be one hiding on the backside of it that threads in from the opposit direction of the first two you remove), and it will slide out. Look at your new starter before you do it and that will be a good indicator of how many bolts hold it in (just see how many holes are threaded). Here is a picture of it. Hope it helps!
[IMG]local://upfiles/3079/C39B1B533B924A8D9CC25A5CC1E62B2B.jpg[/IMG]
Old Apr 7, 2006 | 09:51 PM
hnic514
thanks sir nasty i thought that was it just wasnt sure
Old Apr 7, 2006 | 10:51 PM
lightshow's Avatar
the starter is just left center in the engine bay in sits right on top of th transmission. when you take the bolts out, make sure to remember where they go because i think they are different sizes.
honda409
Feb 5, 2010 10:42 AM
seattlehawk
Jun 6, 2009 05:04 PM
niahuynh
Apr 27, 2009 07:27 PM
mdjbhouse
Dec 28, 2006 08:31 PM
mcrisost1999
Jun 3, 2005 12:45 AM
