Subframe removal
Old Jul 27, 2007 | 02:07 PM
mck52689's Avatar
Default Subframe removal
Im not a genius when it comes to accords but i need to remove the sub frame.... what will happen if i take it off, or move it for a few minutes time.
Old Jul 27, 2007 | 06:28 PM
Shadow1992's Avatar
Default RE: Subframe removal
Subframe?Accords are unibody construction....so what piece are you talking about?
Old Jul 27, 2007 | 07:21 PM
deserthonda's Avatar
frt beam ?
rear beam ? where the p/s rack is mounted ??
Old Jun 14, 2012 | 04:19 PM
4GVN1's Avatar
Question Subframe removal-HELP!
I am going to have to replace the rack and pinion as well as the subframe where the bracket that holds it in place on the drivers side, the bolt sheard off from the subframe and now is loose. Any input is greatly appreciated!
2003 Honda Accord EX
Old Apr 11, 2018 | 02:37 PM
Ttripp's Avatar
I'd like too jump in here and ask a question. Im getting ready to swap out my engine on my 99 honda accord (v6 vtec) I've been told that there isn't enough room for just the engine to cone out the top and to just drop the engine and trans together from bottom. In your comment to someone else you said the frame is unibody. Someone told me you need to remove subframe or k frame? You have any info that will help me do the swap thru the bottom? Only done top engine removal on rear wheel drive before.
pinkfloyd2388
Mar 14, 2023 01:42 PM
ajith
Nov 5, 2012 11:37 AM
my96accord
Jun 11, 2012 09:15 AM
Tek310
Oct 16, 2011 02:43 PM
jfman
Apr 15, 2007 04:30 AM
