Tach Jumps
Old May 11, 2006 | 07:55 PM
imcameron
Default Tach Jumps
I have a 97 EX 2.7 with a 135k miles. Once the engine warms up the tach begins to jump and the engine sounds as if the it is missing. At idle everything seems ok but when I accelerate all symptoms return.
Perhaps a vaccum problem???
Thanks, imcameron
Old May 11, 2006 | 08:17 PM
sir_nasty's Avatar
Default RE: Tach Jumps
welcome to the forum... just to make sure I understand you correctly when the tack jumps it sounds like the engine is following suit? I know someone had a similar issue and it turned out that he just need a tuneup (cap, rotor, plugs, wires etc). Do you have any check engine lights or anything on?
Old May 11, 2006 | 09:30 PM
imcameron
Thanks for the reply. The engine looses power when the tach jumps - it flutters. I recently changed the plugs and changed the O2 sensor. I did have an engine light for the sensor but not for the current problem.
Old May 11, 2006 | 10:44 PM
deserthonda's Avatar
it sounds like engine has a slight miss,,,,,,,,,,,what brand and what kind of plugs did you install?? it should be the NGK ZFR5F-11.. have you checked plug wires ? no chk engine lite correct ? did you chk the distr cap ?? And you did clear the computer after replacing the o2 sensor ,, right ?
Old May 12, 2006 | 12:05 AM
Chiovnidca's Avatar
ORIGINAL: imcameron
Thanks, imcameron
Is the check engine light on?
cutlass327
Oct 27, 2012 12:58 AM
92AccordOwner
Jul 31, 2011 10:02 AM
Masterofsandman
Sep 8, 2009 08:18 AM
90HondaEX
Oct 13, 2006 01:40 AM
mwg98
May 15, 2005 07:31 PM
