Tbelt & Wtr Pump rplcd -now problems
Hi guys yesterday my cousin and I replaced my timing belt and water pump on my 94 Accord Vtec. After we did every time I tried to start it when it was cold the engine would run really rough then start running smooth after a minute or so, also after letting the car sit and idle it began leaking oil from what looked like 1 of the seals. Any suggestions as to what might have happend or wht I need to do to fix this? Any and all help is appreciated thx!
Check engine crankshaft to camshaft timing is aligned, both at TDC together.
There are many seals that can leak. If valve cover seal is disturbed during timing belt, it's easy to get a leak.
Better description of oil leak necessary.
[QUOTE=TexasHonda;371769]Check engine crankshaft to camshaft timing is aligned, both at TDC together.
good luck[/QUOTE
Ok so found and replaced front balance shaft seal, and made sure everything was in time, but now that it's all together when it's starts cold it'll run rough then when given gas will smooth out, also as I'm driving if I step on the gas it will pop and feel like it's missing. Any ideas?
good luck[/QUOTE
Well I also just replaced the plug wires & plugs and now the popping has progressed to all the time not just when I'm accelerating
think my timing might still be off a little!
Stonent
Aug 2, 2012 07:18 PM
