throttle body
Old Sep 9, 2007 | 02:33 AM
02BlueAccord's Avatar
Default throttle body
its been awhile since ive posted here. but i got a question i have a 2002 accord and i wanna know if the throttle body will add 8hp and 10tq. i know it prolly wont but maybe with all the other stuff i have on my car already it might actually. and is it even worth it?? i could use your input.. thanks...
Old Sep 9, 2007 | 11:03 AM
honda97valdeez's Avatar
Default RE: throttle body
I don't think it could hurt anything but the ol' wallet.
Fenix's Avatar
dont know if those claims are true, but someone provided me with a great link to get your TB bored http://www.maxbore.com/seems like a good idea to me. I just dont like the down time of not having a TB in my car.
Old Sep 9, 2007 | 11:11 AM
the skunk2 TB claim a 10hp increase i think, but they are pretty expensive
Old Sep 9, 2007 | 12:15 PM
ya everyone claims different gains. what about the space. does the throttle body spacer do any gains? cuz ive heard those will give you gains as well
Old Sep 10, 2007 | 10:47 AM
falkore24's Avatar
I have a spacer and it doesn't do anything but make a little noise. I'm interested in a larger TB also, but I've heard mixed opinions on it. It seems that there is not enough metal to make boreing the stock worth the effort. Eddlebrock makes a 70 and a 75mm TB and adapter plate that they say works on our cars, but I haven't done enough research yet to see what I'm going to do.
Old Sep 10, 2007 | 10:49 AM
00AccordLX5spd's Avatar
Registered User
I wouldn't waste my money on it.
Check out this thread: https://www.hondaaccordforum.com/m_70093/tm.htm
The same principle applies.
Old Sep 10, 2007 | 10:57 AM
falkore24's Avatar
If I do it I will match the manifold to the larger TB ..... also been thinking about polishing the IM myself ..... no runner porting, just polishing the rough surface off while it's off the car for TB matching. ..... if I do the TB.
Old Sep 10, 2007 | 02:29 PM
Registered User
I bet a larger TB may actually work on a V6. I just doubt it on a 4 cyl.
Old Sep 10, 2007 | 02:56 PM
A cheap vacuum gauge can give you an idea. If the manifold vacuum is already weak (at WOT) then you can be pretty confident that the wide-open throttle isn't producing much restriction.
By connecting the vacuum gauge at different points, you can try to measure where the air loses pressure. Across the filter element, vs. across the TB, vs. anywhere else you can hook up the gauge...
