timing gears?
Old Apr 28, 2007 | 08:14 PM
RabidGoat's Avatar
Default timing gears?
Hey there, I am new here obviously and i would like to start here with a question. I have a 93 accord ex with a 2.2 dohc f22b. i was thinking about getting adjustable timing gears and i didnt know which ones to get, or which ones were right. Since I would need 2 gears, would i just get two of the same ones or are they different? The summit racing site didnt help much so i didnt know where to turn. thanks in advance.
Old Apr 29, 2007 | 01:41 PM
Shadow1992's Avatar
Default RE: timing gears?
F22B, sweet someone did a swap for you, or did you do it? Both are the same, so you would have to buy two, unless you could find someone selling a set of them. As long as they are meant for the f22b, then they shouldn't be a problem. Since the f22b came int the 94-97 accords, you can search sites for cam gears for that model. AEM, Skunk2, Unothordox Racing are some really good names.
Old Apr 29, 2007 | 06:58 PM
RabidGoat's Avatar
thanks for the info can i use h22 or h23 cam gears?
Old Apr 29, 2007 | 08:39 PM
Shadow1992's Avatar
H22 should also be compatiable, but I can't garauntee it.
Old May 4, 2007 | 11:56 AM
RabidGoat's Avatar
ok thanks. yea the f22b was put into the car before i bought it. although i am starting to mod it now.
pancho88
Mar 18, 2012 04:14 PM
nygamble
May 1, 2006 07:51 PM
HondaLawgik
Apr 18, 2006 02:28 AM
cache
Apr 16, 2006 04:43 PM
