Transmission on 96 Accord
Old Sep 13, 2006 | 03:48 PM
96hondaaccord's Avatar
Default Transmission on 96 Accord
I notice the transmission has a delay when I first put it in gear. It is like a 2-4 second delay then it shifts into gear(it is an Auto.) Then I can press gas and go. I have had the transmission flushed and it still seems to do it. Any ideas would be a great help.
1996 Honda Accord with 170,000 miles I4 2.2L non Vtec
Old Sep 13, 2006 | 05:22 PM
YeuEmMaiMai's Avatar
Default RE: Transmission on 96 Accord
the only advice i can give short of rebuild is live with it. (check vavle is leaking and allows fluid to drain form TQ converter) try drain an fill with honda atf.
Old Sep 14, 2006 | 04:19 PM
So what you are saying it is eventually going to give out? I would like to fix it. I was hoping it was inexpensive. Thanks for your help.
Old Sep 23, 2006 | 08:14 PM
sssexy70's Avatar
Just to help you out, my 1997 does the exact same thing, and my family has always had hondas and they are generally known for slow clutches... it doesn't sound like your car has a problem at all, its just the model.
MessAround
Aug 13, 2011 09:45 AM
