v6 accord 2007 engine weight
I think the 200hp J30A1 weighting around 250lbs, and the 240hp J30A4 engine weights 20lbs less an about 1" shorter than the J30A1 because it's using a three-way VTEC system, higher (10:1) compression ratio, and a novel exhaust manifold cast as one piece with the cylinder head.
