Viberating and low power issue
Old Nov 28, 2019 | 06:14 AM
Saleem Ullah Malik's Avatar
Default Viberating and low power issue
i have accord 95 ex with f23a engine runing with ob1 orignal accord ecu POE.The problem is that there is engine missing problem no check light on.tps map coolent tempt sensor and iact valve checked and replaced.also all four injector are checked with multimetre and with tester.resistance box also good.but when i throttle vehical jerking and accelerating.it means low power.and if map sensor wires changed like signal wire on reference wire and refrence on signal wire then jerking gone but black smoke blows from exuast.what should i do.if any one give some help
Vincentmb615
Nov 8, 2019 11:30 AM
RobinsonRicer
May 29, 2013 10:46 PM
razyn
Jun 12, 2012 05:38 PM
sofireguy
Apr 6, 2009 07:28 PM
bougie_44
Dec 30, 2006 11:40 PM
