VTEC wiring help please!!!!!
Old Oct 13, 2008 | 01:39 PM
FarRockAccord's Avatar
Default VTEC wiring help please!!!!!
need help wiring the tec in my car.....what two wires are do i tap the vtec to???? I did a swap thanks to my homie...up for three days straight because we dropped the motor from one car to the other which means swapping out two motors and putting them back in and we were too tired to wire the vtec because it was dark and i have the automatic ecu from a an obd1 ex.....now please help me with the rest.....need the wiring diagram or somethin...thanx in advance
Old Oct 14, 2008 | 09:07 AM
00AccordLX5spd's Avatar
Registered User
Default RE: VTEC wiring help please!!!!!
I really wish I could help you here. If I were you, I would go to the DIY section and download the shop manual for a 94 Honda Accord EX. There is link to a free one in there. That is where I would start.
Old Oct 14, 2008 | 09:23 PM
finch13's Avatar
Hmm... Hm... Hm... my VTEC knowledge is eluding me. Try searching forum . pdmfi . org for Accord ECU pinouts... You may need a VTEC engine harness and VTEC ECU...
Old Oct 14, 2008 | 09:54 PM
I believe pin A4 is VTEC Solenoid Valve and pin D6 is VTEC pressure switch
Old Oct 15, 2008 | 07:05 AM
But it has to be an ECU from a vtec car. A non-vtec ECU has those pins but they dont do anything.Might not even have wires at that position in the harness.
Old Oct 15, 2008 | 10:55 AM
Registered User
He says he has an ECU from an OBDI EX (that would be VTEC if it is a 94 or 95 model). But I noticedhe said the ECu was from an automatic. I'm not sure if that will hurt anything or not.
Old Oct 15, 2008 | 10:57 AM
cant run a manual tranny with a auto ecu
Old Oct 15, 2008 | 11:12 AM
finch13's Avatar
Manual trannies don't have anything to run, lol. You can use an auto VTEC ECU if you need/want to.
On the other hand, you can't use a manual ECU with a auto tranny, the ECU doesn't have the chipset to communicate with the TCU. You'll get a blinking D4 light, but the tranny will operate normally.
Old Oct 15, 2008 | 11:16 AM
I stand corrected............and how can he get a blinking d4 light if he doesnt have a d4 light
Old Oct 15, 2008 | 11:23 AM
finch13's Avatar
Obviously he can't, I said that for people using a manual ECU with an auto tranny... like I was when I had my 5th gen.
I tend to direct all ECU related questions over to pgmfi.org, they are Honda ECU tuning Gods.
99accordf23a5
May 6, 2014 12:51 AM
Wiley-X
Dec 5, 2012 05:22 PM
96fseries
Mar 15, 2008 07:19 AM
96fseries
ryan ortego
May 19, 2005 06:06 PM
