water in my gas
Old Dec 10, 2008 | 08:28 PM
kamekako
Default water in my gas
is there a simple laymans test to tell if there is water in your gas. I have been getting a bit of loss of power on my 1997 honda accord lx and a bit of sound coming from the tailpipe with a bit of jerking of the vehicle. It will loss power 1 second and then rush off the next. I recently started using E10 (10% mixture of ethanol in gas). Any suggestions as to what might be the problem would be appreciated.
Old Dec 11, 2008 | 11:51 AM
00AccordLX5spd's Avatar
Registered User
Default RE: water in my gas
Try some octane booster and see if it helps. If it helps, it may be a problem with the gas.
Old Dec 11, 2008 | 12:04 PM
finch13's Avatar
Also, ethanol, like any alcohol, loves to attract water.
Old Dec 11, 2008 | 01:58 PM
falkore24's Avatar
I say, run the tank down as low as you are comfortable, then pour in 2 bottles of drygas, drive a bit, braking violently to mix it all up, drive until you are scared of running dry, then refill the tank at Shell or Texaco.
bjr001
Nov 25, 2010 12:05 AM
VZ2
Sep 3, 2009 12:25 PM
BostonPuppyDawg
Oct 3, 2006 01:24 AM
jcharvolin
Sep 26, 2005 05:53 PM
joshuaaaronalpert
May 31, 2005 07:05 PM
