which way to go????
I have a 96 accord 4dr with the 2.2 vtec motor and 5 sp tranny but i would like more power.
Should i go with a h22 swap
or should i boost my motor i got now
Which way would u suggest and why and yes cost is an issue
Any advice is much appreciated
Build and boost your f22... Or go all out and boost an h22... Either way, im sure you will be happy... The turbo f22 will probably make more power to start out... And either mod is going to involve quite a bit of work...
In my opinion I would do a turbo f22... It will make more power than just doing a h22 swap...And either way you go it is going to involve alot of work... Do some research and see what would better fit your needs...You will be happy either way though im sure... Both would be a seat of the pants difference for you...
skipisley
Sep 17, 2012 12:51 PM
ItsaHonda
Apr 1, 2007 12:48 AM
