What engine ?
Old Nov 8, 2011 | 12:07 PM
dfosh's Avatar
Default What engine ?
I have a 1997 accord sedan ex auto trans with 2.2 4 cyl engine . How do i id the engine vtec or not ? Car was built in us. thanks for any info.
Old Nov 8, 2011 | 12:13 PM
g22cd5's Avatar
Supper Moderator
see if your valve cover says "vtec". Or check your engine code inside the engine bay. Under the 1distributor will say "f22b1" "f22b2" fallowed by numbers. But since you have a ex you should have a f22b1 (vtec) engine.
Old Nov 8, 2011 | 12:54 PM
dfosh's Avatar
Vtec is not on valve cover . Numbers on block is f22b2 below that is 4500950.I bought the car new so everthing is orig .
Old Nov 8, 2011 | 03:24 PM
g22cd5's Avatar
Supper Moderator
you have a NON vtec engine if you have a f22b2 engine
StatzFinest
Feb 10, 2008 11:32 AM
xaznxeclipsex
Sep 28, 2007 02:05 PM
thunder_x
May 30, 2007 04:21 PM
blahblah
Mar 18, 2007 02:33 PM
hopkinted
Dec 30, 2006 04:41 PM
