what is a good price for a used manual transmission?
Old Apr 28, 2007 | 02:24 AM
thunder_x's Avatar
Default what is a good price for a used manual transmission?
looking for a used manual tranny for my car to swap out the automatic, but i dont want to overpay for one either...
im probablly gonna go to the junkyard and find one that's in good condition to buy
Old Apr 28, 2007 | 12:16 PM
sssexy70's Avatar
Default RE: what is a good price for a used manual transmission?
Have you looked into all that you need for the swap? You can't just put in the transmission and go... theres a million parts you need!
Old Apr 28, 2007 | 01:03 PM
thunder_x's Avatar
can you tell me what i need?
ive never done this before
Old Apr 28, 2007 | 02:11 PM
sssexy70's Avatar
Nor have I because of the intensity of the project... you need transmission, gearbox, new sensors, clutch pedal, linkages, etc etc etc...
Old Apr 28, 2007 | 05:19 PM
thunder_x's Avatar
shift ****, shift boot, and do i have to change the gauges?
since the gauges for the automatic are different from the manual
Old Apr 28, 2007 | 06:35 PM
deserthonda's Avatar
ORIGINAL: thunder_x
Based on your questions i am not so sure that this is something that you might want to do ( no offense )
but as for what you need
manual tranny of course, pedals assembly , clutch master + slave cylinders, hydraulic lines, shif rods, different computer, clutch kit, flywheel, different center console, etc etc ...
http://honda-tech.com/zerothread/1237137
read up on this ,, it will give you a better idea
Old Apr 29, 2007 | 03:39 AM
thunder_x's Avatar
cool, thanks
Old Apr 29, 2007 | 03:42 AM
thunder_x's Avatar
wow..
that is a lot of stuff to get, how much do you think it will cost total?
parts and labor?
someone on this civic forum said he swapped his for 800 parts and labor, that's unbeliveable
Old Apr 29, 2007 | 10:37 AM
sssexy70's Avatar
Parts maybe... definitely not labour... if you got someone to do it (if you can find a mechanic that will) it'll come up to about $2000 and personally, for that much money I'd rather go turbo!
Old Apr 29, 2007 | 11:08 AM
marbro's Avatar
labor is cheap when you do it or if you have friends to do it
