What happened to my electical?!
Old Feb 1, 2008 | 05:34 PM
Nova's Avatar
Default What happened to my electical?!
When my radiator blew, anti-freeze blew everywhere, including my fuse panel and even all the way to my alternator.
What I didn't know, is that my key was on acc. for the past week and drained my battery dead! So I jumped it and moved it to the garage (about 10 feet away) and my battery light stayed on the whole time...
I took my radiator out while the battery charger was on 10 amps. After I took the rad. out, I turned the charger to 60-amp jump and started the car. With the charger still at JUMP, I ran the car for a second, just to see if the battery light would turn off. I revved up to 3500 and it started to misfire and not run past that.
I shut it off and went to the front of the car, where I noticed the fimiliar smell of burning electrical.I quickly disconnected the charger and figured out where the smell was coming from;my alternator.
I tried to start the car again and the battery was dead. I checked the terminals and tried again. Nothing. So I put the charger on it again and it startedfine again, so I pulled the charger off and went back inside to check my lights and heater and such, and I noticed my battery light was on yet again.
Here is the twist:
When I turn my lights AND heater on, the battery light turns off. When I turn them back off, the battery light turns on again!
Did I blow an internal regulator??
I lost my DMM a while ago, so I can't check the voltage.
Old Feb 1, 2008 | 06:24 PM
sir_nasty's Avatar
Default RE: What happened to my electical?!
It sounds like your alternator is overcharging the system and when you turn a few things off it creates enough of an additional draw that it doesn't register an issue.... without a voltmeter it's going to be nearly impossible to diagnose an electrical issue.
Old Feb 2, 2008 | 01:23 AM
Nova's Avatar
If the problem is an internal voltage regulator, could I replace it with an external regulator?? I really don't want to take half the engine downto replace this alternator.
hiofcer
Aug 31, 2009 07:36 AM
jeffbrand
May 14, 2008 09:11 AM
starky34
Nov 8, 2007 09:34 AM
York
Aug 25, 2007 03:16 PM
mercski
Nov 26, 2004 07:39 PM
