Whining at idle
Old Aug 11, 2019 | 11:04 AM
2009accord 2.4's Avatar
Default Whining at idle
Is it hurting the internals not changing out oil pump gear for the whine ? Got the whine Don't look to bad to do, been mechanic for 35 years , thinking on doing chain , oil pump , tensioner all guides etc! All Honda part?
Old Aug 12, 2019 | 10:36 AM
Have you ruled out external stuff like the alternator? A diode bridge starting to go bad & cause a whining noise.
As far as the chaincase stuff, it seems like they don't go bad unless it has a history of allowing the oil level to drop. There is a way to check the extension of the chain-tensioner, but I don't remember the details. You remove the crankshaft pulley (for the serpentine belt) & unbolt a little cover to see the tensioner. If you're doing that kind of work you might want to get a shop manual for all the details (tightening torques etc).
96hondaaccord
Aug 11, 2006 01:36 PM
wj2
May 25, 2006 05:07 AM
wj2
Sep 16, 2005 03:10 AM
Jun 16, 2005 10:54 AM
cgarcia275
May 15, 2005 07:47 PM
